f.krajewski »
https://forums.nicoclub.com/f-krajewski-u52633.html
Sat Dec 23, 2006 4:30 pm
I had the same issue in my '71. The fat (2") hose that feeds from the gas cap fractured. I used a product called "Goop" to effectively "caulk" the wounds. If you could get a friend to safely blow air quietly into the gas tank inlet while you listen in the trunk you should hear hissing at the point of the problem. Good Luck.
