95KoukiS14 wrote:It only comes when I turn on the defroster and sometimes the heater. So I guess I have to replace the o-rings in my injectors...right? Because I plan to do that either way since I'm running rich.......just have to wait for the weather to get alittle better.
1) The passenger compartment intake vents are under the wipers, which is a good place to pick up smells if you have leaks under the hood. And of course, the defroster vents blow air close to your nose.
2) Injector o-rings fit around the outside of the injector inlet, and seal it to the fuel rail. They have nothing to do with running rich. Now, an injector with a leaky nozzle might do it. And so might a bad oxygen (O2) sensor, or a million other things. But not o-rings.
