Smartphone mount
kcob
Car: 2015 Rogue SL AWD
I am trying to put a smartphone mount on the 2015 rogue dash (soft touch) right over the air vents in the center. Tried 3 different mounts and none of them manage to stick, guess it's because the dash is soft touch material and may be the mounts need something firmer.
Anyone's been lucky with this?
D-Rock
Car: 2008 Rogue S AWD
2009 Rogue S AWD
2011 Rogue S AWD
2014 Rogue S AWD
I've been trying to find a Canadian supplier for a mount that uses the CD slot. This would put it close to the desired location at the vents in the case you're describing. These same mounts apparently fit in tight seams as well so I was thinking either the CD slot or in the vertical seam to the right of the center display.
yearoftherat
Car: 2015 Nissan Rogue SV AWD
Have you looked at the vent mounts by Kenu?
There is also this option:
TUPELO Smartphone Universal CD Slot Car Mobile Phone Mount Holder Cradle for Iphones, Ipods, Samsung Galaxy, Nokia, HTC Cell Phones, LG, Blackberry Smartphones and Android Devices- Black https://www.amazon.ca/dp/B018G6VLV6/ref ... EwbE1MGX23
kboo74
Car: 2015 Nissan Rogue SL AWD Premium Pkg (Former)
2017.5 Nissan Murano SL Tech Pkg) (Former)
2019 Acura RDX A-Spec with Tech Pkg Performance Red
I have the iOttie Easy One Touch 2 Car Mount Holder for my 2105 Rogue SL AWD holding an iPhone 6s Plus. Its great and has execellent holding power. This is my third car with a dimpled dash and this holder has been the best so far. Got it on Amazon.
Iowa
kboo74
kboo74 wrote:I have the iOttie Easy One Touch 2 Car Mount Holder for my 2105 Rogue SL AWD holding an iPhone 6s Plus. Its great and has execellent holding power. This is my third car with a dimpled dash and this holder has been the best so far. Got it on Amazon.
Just picked up the new iOttie One Touch 3 and it comes with a pad that sticks to the dash on your Rogue and then you mount your One Touch 3 to it. Loving it so far and no problems.
Ken
yearoftherat
Ken
The newer versions are def better due to the use of the gel pad that allows it to be removed and placed anywhere unlike the cheap 2-way tape ones.
kboo74
kboo74 wrote:
kboo74 wrote:I have the iOttie Easy One Touch 3 Car Mount Holder for my 2105 Rogue SL AWD holding an iPhone 6s Plus. Its great and has execellent holding power. This is my third car with a dimpled dash and this holder has been the best so far. Got it on Amazon.
Ken
Caught my own mistake, I listed the One Touch 2 instead of the One Touch 3.
Ken.
Rogue203
Car: 2016 rogue sl
I have this one in the rogue for my wife and its mounted to above the passenger glove box on the cf type of trim Angeled at the driver and it works absolutely awesome
http://www.walmart.com/ip/magicMOUNT-Da ... 3=&veh=sem
jjcendana
Car: 2014 nissan Rogue X-Trail
I bought a cd player mount for my phone and it works perfect I have a note 3. Here is the link for what I bought. https://amzn.com/B00YZO04CQ
Return to “Rogue Forum”
