NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Wed Mar 14, 2018 3:06 pm
Again, just looking at the weight distribution ratio is an oversimplified approach, lots more at play here and if you are going to compare a vehicle designed and built in the 80s and one designed and built today what do you expect Its not just about weight distribution, its about tires (like you said) suspension design, downforce, AWD vs RWD, traction control and electro-nannies. IN the case of the Z32 2+2 you are correct it 53/47 (vs 2+0 55/45) but I would be careful making an all encompassing statement because the point of reference (middle of the car between the axles) changes when you elongate it and the majority of the weight stays at the front. Also you are backing up my original point about the car becoming more tail heavy which would wreak havoc with how it handles because the engineering that went into it was done for a specific weight distribution. Its a chain reaction.
