Smaller master cylinder ? Turbine housing slightly touching please help...
1.8turboterror
Car: 1989 240sx with a built ca18det
Please help are their any shorter master cylinders because im having an issue with my new turbo it is slightly Touching on the edge so bad that i sanded the housing a lil with a dremel and sanded the master a lil and it still basically touching what are my options if any thanks guys and don't say buy a different turbo by the way its a precision 6262 billet ball bearing if that helps anybody
BACARDI_DWB
Personally I would not risk my brakes being degraded with a smaller master cylinder to put more power down.
I suggest modifying your exhaust manifold. either pull it closer to your head or pushing it further forward. change the mating for your turbo (machining the flange for the turbo to "tilt" to see if that gives you more room.
if Push comes to shove make a new manifold.
Modified by BACARDI_DWB at 8:59 AM 4/2/2010
1.8turboterror
Thanks man yea i had my car towed to the shop their making me a custom front mount turbo should be ready in two weeks brakes are definetly important i agree
DALAZ_68
Car: 90' 240sx CA18det
how
1.8turboterror wrote:Thanks man yea i had my car towed to the shop their making me a custom front mount turbo should be ready in two weeks brakes are definetly important i agree
about some pics sir
