mike7401 »
https://forums.nicoclub.com/mike7401-u107747.html
Tue Feb 02, 2010 3:33 am
The one thats on the main air I pulled out and cut off circle piece off and used it like a coupling. But the other side where it connects to also broke, that is the side were it looks like a vacum block 2 ports, put a screw in it and block the side on intake. the oter port is still attach which I believe is for the egr. But its still amazing how better it feels. It could be like Paul said vac leak, but yesterday when I opened the hood the side on main intake tube plug fell off and was still driving great the side on the vac block sort of thing was still plugged. Capped off the intake side again. I pulled codes and got knock sensor which I knew about and also injector leak code, I know my number 1 injector is omhing at 15.27, the rest are fine will changed when I due knock sensors. BUt I get a flashing airbag light now maybe I did something wrong when I pulled codes from computer. But she feels really good
