WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Wed Oct 25, 2006 6:41 am
I dunno where this came from, I've never seen it for myself. Oil shouldn't just leak past a seal for no reason, unless the seal is bad and your filthy oil is simply acting like a clog, or scab if you will. Then the switch to a really good synthetic removes the debris.
What weight oil are you using? Syntec is fully synthetic by the way. I have always run 20-50 Syntec or Mobile 1 in everything to include to Skylines.
I'd try a heavier oil if you're using a light weight.
Boosting isn't going make your leak better or worse at this point, unless you have serious blow-by and you're pressurizing the crankcase.
WD
