small problem, need some advice.
Seanzyyy
Car: 1990 240sx se coupe
my car is having the same problems it had when one of the spark plugs was f***ed.
when i give it gas it slowly starts to die, but the rpms go up like normal.when this happens, my car spits out black smoke.i turned it off, tried to turn it back on and it would just crank.. gave it gas when doing this after a few failed attempts and the car would turn on, then die right after.
first time around it was the sparkplugs.now i dont know what it is...
any suggestions?
93drifter
Car: 1993 240sx Hatch
Well Black smoke would imply your running rich, excess fuel.
So I'm gonna assume you have an issue with fuel somewhere. Is the car stock
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Pull and check the plugs again. Could be a bad fuel pressure regulator. Might also be an injector or two went bad on you. Are you using any type of aftermarket ECU and/or fuel system upgrades (pump, injectors, etc)?
Seanzyyy
car is stock,no aftermarket ecu or anything.
im going to pull the plugs and check them.they should be ok though since theyre only a few months old..
i also need to change my o2 sensor.think that could be related to the issue at all?
J14cm7
Car: 95 240sx S14 SR20det
Search around a bit it could be anything. There are a billion threads on this exact issue.
ScrapMetal
Car: 1999 Chevrolet S10
1991 Ford Bronco 5.0
I had a similar problem and it turned out to be the Crank Position Sensor, but in your situation it could be many things. Good luck buddy.
scotty-2-forty
Seanzyyy wrote:... i also need to change my o2 sensor.think that could be related to the issue at all?
Yes, absolutely. Could be stuck in lean mode causing it to run rich. How do you know the sensor is bad? But yes, that could do it!
Seanzyyy
I dont know for sure, but if im running rich, it wouldnt hurt to replace the o2 sensor since its fairly cheap.i dunno if thats the original o2 sensor or not... lol
but yea,it is definitely fuel related. when it has starting prolems and its just cranking while i give it gas i can smell gas...
i'm going to replace my o2 sensor asap,
i did the spark plug wire check by pulling the wires off one by one while the car idled and everything was ok...
im pretty stumped with this.
on the bright side...im getting a pretty good chunk from tax returns...
