clss240 »
https://forums.nicoclub.com/clss240-u85743.html
Tue Apr 08, 2008 11:58 am
my idle is fluctuating from 650 to 900 no backfiring or anything. i did a lot to the motor and before i took it all down it idled fine. i did the cam swap and a few otehr thing while converting this obdII block to my obd1 harness and ecu. now i did use the s14's upper intake manifold w/o butterflie could this be casuing it? also i dont have any of the wires going to the upper connector on the tps. as i cant find them in the fsm and dont know which way they go back into the connector. any other help? is it supposed to idle a little weird after the cam swap? when im accelerating and at wot the engine purrs!
