USMCgetsome »
https://forums.nicoclub.com/usmcgetsome-u15451.html
Fri Jun 09, 2006 9:32 am
So i heard this wierd noise (VIBRATION) coming from the engine bay. So i took a look at it today and heard it coming from the cam shaft intake side. Number 1 cylinder. So, i ended up retorquing all the caps down and it went away. So i decided to check the sparkplugs and i found a bkr5e-11 in the #1 spot. So then i checked the rest and they are all bkr6e-11. I figure that is what was causing my lil backfire problem.
I'll post up in a few hours and let u guys know if everything is kosher. I also have notice that my oil pressure was directly affected by that vibration of the cam shaft.
wierd symptoms.
