nickelghandi »
https://forums.nicoclub.com/nickelghandi-u215217.html
Fri Feb 23, 2018 6:35 am
You might already know this, but once you are sure it is not leaking, and maybe even before, you should drain, flush with distilled water, and refill the cooling system with fresh coolant. Bar's leaks can kill things like water pumps, thermostats, and radiators. It isn't as bad as some, but it can definitely still clog things up. Three tablets shouldn't do much, if any, damage, but better safe than sorry.
