Small Bulb Size??
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
What size are the small bulbs on the 2006-2007 headlights that are always on if the lights are on (in the low beam area that are only for looks)
I want to swap them out for a bright white instead of the yellow that does not match the upper projectors.
The yellow ones in this picture
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Bumpity
joe603
Car: 2014 Durango R/T
You mean the turn signals? I've seen a G35 with the light housing modified using an outdoor spotlight bulb....
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
NO the lower part of the headlight... see how it's lit up yellow? there are two bulbs in there one is the Low/High Beam and the other is a small bulb just to light it up for looks... THAT's what I need to know the size for.
k@osx71
Car: '04 G35 Sedan DP
I would also like to know wth that bulb is. What does it do? I just changed my fog lights to PIAA Extreme Whites and it has a little yellowish glow on it 'cuz of that little bulb.
Rivalry
I don't mean to sound like a smart-*** or anything, but have you tried to take it out and hit Autozone or some place with lots of auto light bulbs?
If not, try http://www.sylvania.com/Consum...uide/
Good luck.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
I only have one car ATM (Well at my location) and it's a PITA to take apart the fender liner and take off the wheel just to put it back again to go to the store.. THEN take it off again.
Rivalry
Did you check the link I posted? Based off the names they have listed, I think it's
Front sidemarkersize - 194
k@osx71
Rivalry wrote:Did you check the link I posted? Based off the names they have listed, I think it's
isn't that the corner lights? I think Rivalry was talking about the small bulb right next to the fog lights inside the headlight housing (well thats the one I was referring to anyways)... I'm sure they're wedge bulbs though~
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
Kenrik wrote:NO the lower part of the headlight... see how it's lit up yellow? there are two bulbs in there one is the Low/High Beam and the other is a small bulb just to light it up for looks... THAT's what I need to know the size for.
Sounds like he is talking about the high beam/ fog light. The low beam bulb is its own bulb or HID. I have HIDs on mine and I added/replaced the fog/high beam bulb with a Hella White Bulb - forget the model. The light is very white and a nice compliment to the HIDs. The bulb # is 9003 - Sylvania lists it as High Beam - but on the G35 the High/light is the same bulb.
Kenrick - your light looks really yellow - hard to tell from pics if it is the stock "yellowish" look or if someone replaced the fogs with a yellow bulb.
Cali 2 Balti G
Dodge Ram Quad Cab
Toyota Sequoia
Uh never mind - I now realize that the 2006 headlights have an additional bulb that my 2003 does not.
You have probably firgured it out by now. if not try comparing the sylvania recommendations for the 2003 and compare it with the recommendations for the 2006 - maybe the Small Bulb you are looking for will appear in the 2006 reco and not the 2003.
Good Luck
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
In that picture the fog lights are off. There is a small bulb that lights up the lower area just for looks. That's what I need to know.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Did you find out what it is?
I think its the running/day light bulb
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
No I did not find the bulb yet... You guys suck!
tollboothwilley
is it the same bulb that runs if you have your daytime's on?
mine is a 2003 so, its likely to be different with you havin' projectors, but if i have daytimes on i'll get this soft yellow light on that doesnt illuminate anything really
trevorluken
Car: 2004 Infiniti G35
I just changed out most of all the bulbs in my car. The high beam/ fog light is a h4/9003 the side markers are a 194. The daytime running light you are talking is a 921/194/158 they are all the same bulbs. I put a yellow fog light bulb in mine and looks really good
USAF_G35_Guy
Car: 2003 G35 Coupe 6MT
I feel a little dumber now after trying to follow this thread lol
the light doesn't project at all people! it's just a background/glow affect haha I've got a blue one on mine, it looks clean....but I forgot the part#, sorry dude. good luck with your search.....if infiniti hadn't been so gay when they designed the headlight assembly you could of found out by now
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
yeah it's such a PITA to get to I only want to do it once (so I need to know the bulb before I do it)
C-Kwik
It's the parking light as listed on the link rivalry posted, which would be bulb 168.
You can look at the FSM here:
http://www.nicoclub.com/FSM/G3...Coupe/
Download the lt.pdf file. It's the lighting section. A diagram is located on page LT-34.
