Sluggish running SR...HELP
MrSoutherland
Car: S13 - Sr20
So it's internaly timed but I cannot get the timing light to time it right. I tried the FSM proceedure and a couple others with no luck.
The car runs and drives but is way too sluggish untill after 4K. Around 4500 it hits full boost.
What seems to be the most common problem when it's not boosting till way late like that. Stock setup BTW. I know the timing isn't spot on, but is there a different trick I don't know about? Or why is it not locking in and letting me get to 15*? It's probably 10* off or more right now...
I know I can bring it to a shop but I'm broke. lol! Every coupler is super tight. No vaccum leaks....
MrSoutherland
Car: S13 - Sr20
Ok, someone at least check my check list that I made. Am I missing anything to check for a sluggish running motor? I'm mainly having trouble getting the timing to 15*, Could that be due to a bad knock sensor or wiring to it?
Clean MAFSCheck TPSClean IACVCheck vacuum hosesGap NGK BKR6EIX to .34Check Fuel pressureCheck Knock sens.
ZOOMIGUEL
Car: 1989 240sx SR20DET
2006 Lexus IS250 AWD
check my thread... I believe we have the same problem///
and watch my video
zerothread?id=484018
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
In my experience, a good timing light aids in setting the timing. You'll notice that it'll jump around, but be patient and set it, per FSM.
MrSoutherland
Car: S13 - Sr20
I don't know how you think I have the same problem as you. You have something else going on bud.
MrSoutherland
Car: S13 - Sr20
BTW- My vacuum @ idle is now 10-11..... Decelerating is 20.... <---Normal?
I'm thinking it's my TPS, I just havn't got to it yet.
ZOOMIGUEL
I only said that because when i drive the car it slugs until after 4k rpm [ when turbo knocks in]
93drifter
Car: 1993 240sx Hatch
I'm having the same problem but even after i get to 4k it still doesnt feel like 100% power.
maybe we can meet and compare our problem, i see your in fl
