Sluggish Q45
anton
Car: Historic racing cars(I was Chief Tech for VARA in late '70s-early '80s), early hot rods, F1, and goo
Hello all- I'm back after a long period when my '94 Q45 behaved itself very well.However, a few weeks ago it developed a misfire which my dealer(DIS-Advantage Santa Monica Infinity) diagnosed as a couple of bad injectors. I was told that since it cost about a grand to get to them I should replace them all. Stupidly, I agreed and $3400 later I got the car back.Driving it home I realised that it was running rather poorly- Extremely sluggish acceleration at full throttle until 4000+ then as though a switch had been thrown, normal strong acceleration to redline. I took it to a friend's BMW shop and we gave it a quick look under the hood. All we could see was a couple of vac. hose clamps that had not been replaced correctly so I took it back in the morning. 3 days later it was done and on driving it there was no change. I complained and the tech who worked on it went for a ride with me and said it seemed fine to him. He apologised for "leaving that vacuum line off" and he said there "were no codes showing a problem" therefore it was fixed. We drove another customer's car and it was marginally better than mine but nowhere near as quick as mine had been before the misfire developed.I left before I got violent.I haven't driven it much since then but I notice that it doesen't start like it used to- it sometimes cranks for 2-3 seconds before firing and the transmission shifts a little funny sometimes. They also replaced the "turbine sensor" and 2 other sensors. The tech was a pretty young guy and didn't leave me with a favorable impression. I had the feeling he didn't know the Q45 very well.Is it possible that a vacuum leak or transposed hoses could be causing this problem?I'm pretty good with old Ferraris and Fiat V8s but I don't know squat about modern cars and their systems.Help!Thanks,Anton
Rex
Car: None
This will get more attention when it's moved to Infiniti Online Mechanic
boost_boy
Coil packs! They do go bad and cause all the symptons you speak of.
float_6969
Do the VH's have a cover over them like the CA's do?
