Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Dec 05, 2007 6:02 am
Be gentle with that oil flush stuff... whatever you're using. Q45Tech has recommended a fresh oil change, half can of BG Quick Clean, followed by another oil change, other half can of quick clean - then a third oil change.
The carbon build-up that Q45Tech was mentioning is on the valves, intake components, plenum, throttle body, EGR etc. Not in the crankcase... so if that's the reason you're thinking of an oil flush, it's really not necessary... I tend to avoid oil flushes unless there's a specific issue i'm chasing - since the chance of loosening up something and redepositing it somewhere else is always a concern.
One other question... have you checked your EGR valve's function? It's not monitored by the ECU with the federal ECU, so you wouldn't see a code. Check it by feeling the bottom of the valve while reving the engine at the throttle body. It should rise and flutter between something like 1000 to 3000 RPMs. Then cut out at higher RPMs. You should also be able to manually push it up (open) at idle and cause the engine to choke down or almost choke down...
Good luck
Heath
