sluggish...hestiation.i have the answer
fulmore240
Car: 93 240sx ka24d
my ca was running bad for months i replaced everything i can....fuel pump filter injectors spark plugs wire distrubutor cap rotor MAFS.....till finally i tested the outage from my knock sensor and i got 3.2 when its suppose to read 5...with the multimeter.....so i got a 1 watt or 1 megaohm resistor and hook it up to the white wire going to the ecu from the knock sensor harness....now it runs better then i can remeber......its only a temp fix...knock senso cost over 100 dollars and its a pain to replace...so try it if you must...hope it helps
anday
Car: cefiro
how can u tell the engine has a knock sensor? where is it located?is it available in rb20e engine?
fulmore240 wrote:my ca was running bad for months i replaced everything i can....fuel pump filter injectors spark plugs wire distrubutor cap rotor MAFS.....till finally i tested the outage from my knock sensor and i got 3.2 when its suppose to read 5...with the multimeter.....so i got a 1 watt or 1 megaohm resistor and hook it up to the white wire going to the ecu from the knock sensor harness....now it runs better then i can remeber......its only a temp fix...knock senso cost over 100 dollars and its a pain to replace...so try it if you must...hope it helps
