dividedhighw »
https://forums.nicoclub.com/dividedhighw-u95262.html
Tue Jan 13, 2009 3:51 am
Welcome to NICO, SHB001!
If I can clarify the symptoms you're reporting, is the vibration occurring because the car is running at too low an RPM - leading to engine "lugging" and hence, vibration? If so, you definitely have a problem that should be corrected. Perhaps one or more sensors is faulty, feeding erroneous information to the engine management electronics, so it's upshifting or locking "overdrive" way too soon.
Yes, the EX's transmission is supposed to be adaptive (i.e. programmed to modify shift points & responsiveness based on the way you drive), but don't expect it to do so perfectly - it doesn't.
I've read that Infiniti purposely made the EX's throttle less responsive (compared to the "G", for example) after initial field trials because some testers thought it too twitchy ... this was done to make it seem more refined, thereby enhancing the impression of "luxury" over "sport".
I wouldn't say I have a heavy foot, but I do expect the car to be responsive when demanded, so on that point, the EX has failed to deliver. Now approaching 11,000 km (about 6500 mi) on the clock, mine is just starting to be tolerable in "D". Perhaps given much more time, yours will begin to adapt appropriately to your expectations.
In terms of "downloading" your BMW's learned behaviour to your EX, I would be shocked if that was even possible. These types of parameters (and the way they're saved) are completely vehicle-specific, but hey - one can hope, right?!
Cheers,David
