Scotte123 »
https://forums.nicoclub.com/scotte123-u96684.html
Sat Sep 20, 2008 3:14 pm
Hi Randyboy,
I had/have some similar problems. The guys here helped out A LOT! So give them a chance. Newbies post the same questions over and over again and that gets very tiresome (beleive me, I used to live in a resort town and after you've heard the same thing over and over a gain you can get a little rude).
The more detailed on the maintenance and repairs done the more accurate and detailed the anwers will be. (The pro's here should make up a form to fill out before they will answer..LOL).
My '94 was inherited at 120k miles and had all prior service done by the dealer on schedule. After I received the car the maintenance was done locally. Performance started slipping very imperceptibly, until about November of last year. The crew here diagnosed multiple system failures; the fuel pump, and the knock sensors (KS). I tried to fix the pump and KS myself (bad mistake unless you have a lot of time to do the work). My local guy put it together and found some other issues when it had to be smogged. So now it has new KS, FP, CATS, Pre CATs, EGR, fuel filter, air filter, O2. It runs well but not perfect. Gas mileage is about 20 on the highway and 16 around town.
It accerates OK up to 4000 RPM then it TAKES OFF like it used to. It's FAST over 4000 but sluggish until then. I'm wondering if the FPCU needs replacing or if the timing might be retarded until 4000 rpm. Any thoughts anyone?
Sorry to be so long winded.
