Slow Windows 99 1/2 QX4
Dougmo
Car: Raquetball, running, yard work
The power windows on my 99 1/2 QX4 are extremely slow in cold weather. Is this a common problem on QX4's and is there a solution?
s13sr20chris
the first thing to do is to lube the tracks with silicone spray. DO NOT GET ANY ON THE GLASS(or at least not the part you want to see through, the edges are ok). just spray all over the rubbers and then move window up and down and repeat untill better.
