TCM/ECM/ any software is only uploadable with Consult software. Nissan may be able to do it.StanleyNii wrote:How do I get the ECU retuned. I live in Ghana and we do not have infiniti dealerships here like in the US. Most mechanics here are not that good with these cars either. Is it possible to do the ECU retune my self. If so what do I need and how do i get the ECU software.
BlackCat, I thought it sounded strange myself, but a tech at my local Infiniti dealer and an Indy shop both told me the same thing when I had both F&R diff fluids replaced. They may have been confusing it with the transfer case?BlackCat81 wrote:Contrary to what was previously posted, the clutch for the AWD system is not located in the rear differential. Nothing in the rear diff controls any of the AWD functions.
I am also a journeyman Infiniti tech. The AWD system is a totally traditional system with nothing special about it. Yes, the transfer case is what transfers power to the front wheels via the front differential. The rear end is just a run of the mill independent rear setup. I have valvoline 80w90 in my front and rear diffs, valvoline synthetic ATF in my t-case and trans. It's what we use when doing all our services. I've never had one of our t-cases apart as they're basically indestructible. My 06 M35X is about to turn 205,000 miles.mikew83 wrote:BlackCat, I thought it sounded strange myself, but a tech at my local Infiniti dealer and an Indy shop both told me the same thing when I had both F&R diff fluids replaced. They may have been confusing it with the transfer case?BlackCat81 wrote:Contrary to what was previously posted, the clutch for the AWD system is not located in the rear differential. Nothing in the rear diff controls any of the AWD functions.
"The ATTESA E-TS version uses a mostly conventional RWD transmission. Drive to the rear wheels is constant via a tailshaft and rear differential, but drive to the front wheels is more complex by utilizing a transfer case on the rear of the transmission.
The drive for the front wheels comes from a transfer case bolted on the end of an almost traditional Nissan RWD transmission. A short driveshaft for the front wheels exits the transfer case on the right side. Inside the transfer case a multi-row chain drives a multi-plate wet clutch pack. Drive from the chain is apportioned using this clutch pack in the transfer case "differential" (the system thus does not involve a regular gear differential as in a full-time 4WD layout, but rather a center clutch), similar to the type employed in the Steyr-Daimler-Puch system in the Porsche 959. This unit is lubricated with its own dedicated NS-ATF fluid supply (Nissan Special Automatic Transmission Fluid) and is not in any way connected to the fluid in the transmission. Some Nissan models have an external cooler with an electric pump to cool this fluid."
I'm not sure what it is on the Y50...you can try the Y51 method:StanleyNii wrote:Kindly share procedure on resetting the ecu's
That's awesome! Our Q45 just ticked past 203k last week. Infiniti's are some of the pickiest cars I've ever owned, but if you truly take care of them, they'll easily see 250-300k no problem!BlackCat81 wrote:I am also a journeyman Infiniti tech. The AWD system is a totally traditional system with nothing special about it. Yes, the transfer case is what transfers power to the front wheels via the front differential. The rear end is just a run of the mill independent rear setup. I have valvoline 80w90 in my front and rear diffs, valvoline synthetic ATF in my t-case and trans. It's what we use when doing all our services. I've never had one of our t-cases apart as they're basically indestructible. My 06 M35X is about to turn 205,000 miles.
The only issue I have with resetting all the values by doing an ECM reset is you can possibly lose idle air volume values and accelerator pedal position inputs. There's a specific relearn that needs to be done anytime an ECM Update or replacement is done, same with replacing the accelerator pedal during the recall process. I'd imagine the car would have a general idea of where those values are without the relearn, but I'm not 100% sure since I've never let one leave the shop without completing it.StanleyNii wrote:Yes! I do this when the car is not running. Do you think the accelerator pedal sensor could be the culprit. The VIN check results showed that "Accelerator position sensor recall is incomplete". It could be that the car was shipped out of the United States before the recall. I want to know if faulty ECU can cause acceleration and throttle response problems. Also when you turn on the ignition (without starting the engine) for 20 seconds, the service engine light blinks slowly 5 times. I am suspecting I could be having electrical problems.
