Frozen240 »
https://forums.nicoclub.com/frozen240-u11952.html
Tue Apr 19, 2005 7:30 pm
Here's my setup-jwt ecu, 72lbers, z32 maf.
My car has run good three times now. All three times the engine has been cold and the ambient temp was about ~40F. It was making awsome power for 7psi. Spinngin the tires all the way through first and well into second gear. Then after 15min of fun it's slow again, as fast a switch. It seemed to loose about 30rwhp, by a seat of the pants guess.
I'm really at a loss to figure this out, so I thought I would post it in case someone has had a similar experience.
I have checked out the maf, tps, knock sensor, engine coolant temp sensor, and all are good. Fuel pressure is good (walbro pump) and plugs, rotor, cap, wires, fuel filter are all new. There are no vacuum leaks and the car idles suprisingly well. One thing that it does not do is start when the engine is hot, I usually have to remove the fuel pump fuse to start it when the car is warm, if not it will just flood out.
The base timing is set to 20deg. I do not have any way to check the timing under WOT. I'm not sure if the JWT ecu is pulling too much timing, but why would it do this 98% of the time and then run aggressively when the engine is cold for 15min?
I have a wideband and the AFR's are all good under boost, 11.5-12. They never changed.
I think I've said everything relevant to the situation, hoping that you guys could give me some hints cause I don't get it.
