afracer »
https://forums.nicoclub.com/afracer-u10107.html
Mon Dec 31, 2007 6:49 pm
Drop your oil pan, pull off the valve cover and line up the timing marks on the cam gears and the crank gear at TDC of the compression stroke in accordance with the FSM. It sounds like your timing gear on your crank is off a tooth or two. The easiest way to check it without pulling the whole engine or the timing cover is to pull off the oil pan, baffle plate, and oil pickup. Look for the gold link on the timing chain...with the two silver links lined up with the dots on the cam gears, the crankshaft key should be pointing straight up at 12 o'clock and the gold link should be on the sprocket on the crankshaft at about the 4 or 5 o clock position. I'd say either your timing is way jacked up or compression...so check that too. Other than that if it sounds like it's running on all cylinders and idles okay and has good compression, either your fuel or your timing is way off. Good luck.
