neo240sx wrote:ok I made a leak tester just like you said and I did find a leak. It was an ic coupler. Now I'm pulling 19.5" vaccume I had a hard time hearing the leaks though because I was using a bike pump to provide the air pressure.Next time I guess I'll find a compressor. It was mad getto but worked. Thanks!!
anytime man, glad it helped you out...you should have used a bottle filled with soapy water. you wouldnt have to listen for it but just see it. anyways(we've ALL been there at least once)!!
Modified by S14-NEO at 5:44 PM 2/23/2009
