duckman240sx wrote:....Also i had tried to ground out the FPCU to put the pump on and it does the same thing, if that matters for anything.
You ran a jumper from the pin in the pic (lower left) to ground and no change? Was that a new fuel pump and used FPCU put in by the PO? The used FPCU may have burned out the new fuel pump. Pull apart the FPCU and look for evidence of melted solder joints, especially the ground circuit and where the connector pins tie into the circuit board. If it looks scorched then resolder.
duckman240sx wrote:34 Knock Sensor 35 EGR Temperature Sensor (RH) 46 Secondary Throttle Sensor 51 Injector Analysis
The 46 is the obvious one. Which is what i had confused. The secondary is needed for the TCS, which i dont have, which the ecu is looking for. Correct?.....
Correct. Code 35 may be the same thing. Do you have a fed emissions engine and a CA ECU? Is there a single wire temp sensor at the EGR inlet mounted on the plenum? Post your ECU P/N and we'll tell you what you've got.
Ignore code 34 for now or until you can ohm test the injectors at the harness connector. The KS code should come on when there's engine issues but it's a stored code and does not light up the CEL.
That leaves code 51- Injector Analysis. Have you ohm tested the injectors yet? The connector is in the same bundle as the KS connector.
Unless you have 2 or more bad injectors it's the fuel pump and FPCU gone bad. Good luck.
