Jemdawg »
https://forums.nicoclub.com/jemdawg-u48609.html
Tue Mar 06, 2007 8:14 am
I'd have to say that having the O/D off increasing your pick-up is a fallacy. It seems to work from a roll, but the increase in pick-up from a standstill does not seem to be significant or existent at all. You should be driving with O/D on at all times unless you are in a situation where there are many steep hills. If you note how the revs stay at about 3800 at 20 mph rather than about 1800, you will know that the difference between the revs and redline is much less with the O/D off, so you are offered more torque sooner than with the O/D off. If you are at a standstill, the idle stays the same as it would with O/D on or off, therefore there could be no more torque or hp than the maximum 122hp and 127lb/ft of torque at the crank. I hope this is understandable and somewhat clears this up. Maybe one day I'll bring my V to the track to run a quick test on this, the results should be insignificantly variable.
