seang »
https://forums.nicoclub.com/seang-u122444.html
Thu Feb 12, 2009 6:13 am
You've come to the right place for that! The naturally aspirated ka24e/de topic has alot for your setup, as does this forum. Personally, I have advanced my distributor all the way on my truck, its the same motor you got. I run 91-93 octane now. I ran a 2 inch straightpipe from the catalytic converter all the way back. Some people run 3 inchers on theirs, but the objective here is to get some more TORQUE at highway rpm, a 2 inch is better for high exhaust gas velocity. It does improve the feel a bit, and its not that expensive. Make sure to run the pipe all the way out from under the truck or else you will get terrible boomy resonance. Also, I bought a big square of bulk 2 stage filter foam and zip tied some around the nozzle of my airbox. I previously had a K&N, but that even felt more restrictive than this, and this was way cheaper. My truck sounds pretty good, and power is better. Its not gonna take your breath away, but its a little better. I can't seem to post pics or else I would show you my air filter setup.
