slow get up
sittinsideways
Car: 89 240sx
My 240sx (automatic) is having a slow get up. It stays at 2000 rpms till it hits 35 mph and then it goes higher in rpms after that then it drives like normal. I've rebuild the transmission; replaced the injectors and its seals; replaced the fuel rail; and the fuel filter. I have a exaust leak around the headers and under the car past the converter. Please let me know (anybody) what might be the problem THANKS!!
blues14
Car: 1995 Nissan 240SX GTS-t
try disconnecting the Revolution sensor on the transmission. there should be a connector by the relaybox . I think it is a 3 wire connector.
bruinbear714
sittinsideways wrote:My 240sx (automatic) is having a slow get up. It stays at 2000 rpms till it hits 35 mph and then it goes higher in rpms after that then it drives like normal. I've rebuild the transmission; replaced the injectors and its seals; replaced the fuel rail; and the fuel filter. I have a exaust leak around the headers and under the car past the converter. Please let me know (anybody) what might be the problem THANKS!!
CHeck your throttle position sensor.
sittinsideways
Car: 89 240sx
Thank You for your input
