180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Dec 21, 2006 2:35 pm
Yeah that can happen with crappy seals. You can try to find a rebuild kit with those seals from Nissan, I've had a bit of bad luck with those seals as well with no dice from Nissan for my z31 master cylinder.
What you can do is this. Get some RTV and a siphon. Siphon out the brake fluid till you get the reservoir dry and pop the reservoir off. You'll see the piston for the master cylinder below it, it should still be immersed in brake fluid. Clean up the top part of the seal (without removing it from the master cylinder btw) and the mating surface of the reservoir and apply a thin coating of RTV to the mating surface. Pop the reservoir back onto the master cylinder and let it fully dry. We're talkin at least 8 hours buddy. So might want to do this before you go to bed. Once the stuff's all dry, pour in the brake fluid, it helps to tap the side of the reservoir where it meets up to the master a good couple of taps to get any and all air bubbles out of there while you're topping off your brake fluid.
I reckon though, the reason for the small leak is the plastic is shrinking at a faster rate than the rubber in the master cylinder is, thus causing a leak.
