Slow battery drain via BCM
elevcon
Car: Infiniti G35, Altima 3.5SE
I am trying to locate a battery slow drain (65mA) caused by the BCM on my 2003 Infiniti G35 sedan. Any idea what components connect to the BCM fuse and which component may cause the slow drain through the BCM (50A) fuse.
infinititech1
oh wow...good luck... the bcm controls almost everything inside the car. start testing wires! lol i never had one with a drain on a bcm. only time i replaced one is cause the dome lights wouldn't work and the bcm controls the ground for the dome light. get a wiring diagram and start testing
infinititech1
you may have a bad bcm itself...
mukesh1911
Car: inifiniti
check alrm check radio&a/c most time prob....
