bentsprocket »
https://forums.nicoclub.com/bentsprocket-u10027.html
Tue Sep 16, 2003 3:03 pm
Ok here we go!!!!
I recently replaced the timing chain in my 93 240 KA24DE. The car ran great before it was just time to do some routine work on it. I replaced the stock intake with an Injen, 3" catback, obx short shifter, replaced the spark plugs, wires, and cap plus rotor button. I put in a new clutch and new seals all through out the car top to bottom. Now to the problem it's been having first after all the work was done above. I went to start it. It started but it was out of time bad so I put it in time went to eat and came back for round 2. I lost!!!! The car would not start. I double checked everything from vac lines to elec connectors all were good. I gave up not having a FSM (I know shame on me got one coming). I ended up taking it to someone my old man says is good and stands behind his work. Well he got it started and I picked it up and low and behold it ran like crap. He said the coolant temp sensor was grounded out. Anyway it runs sort of. Now the idle is bobbing and the car backfires alittle runs like crap still. Anyways stuck a timing light on it was 50' BTDC imagine that no wonder huh. Anyhow I was thinking it's fixed. Nope but runs alot better and gas mileage greatly improved. But still not herself!! She has got a clean AIV retrieved that info from you guys thanks but wasn't that. Changed catalyst converter not it either. Used injector cleaner help alot but still not up to par. THE SYMTOMS ARE AS FOLLOWS NOW. When you let the car idle it loads up and tries to fload itself. That takes about 4 mins to do if you let it idle for a second after starting cold or warmed up. I can slowly press the gas and it revs fine if you put the pedal to metal it goes f***ing crazy spits sputters then catchs up with a black exhaust cloud. Its does this from 750 to 2250 rpms after that it's fine. Also power is lost have to gear down now to climb small hills on interstate and can't pass anyone. If you understand this then please help me and my car. I love it to much and don't won't to start to look for another means of transportation IE HONDA I would rather push a nissan b4 driving a honda. I have a TPS but haven't installed it yet. Also new fuel filter. Well thanks for the time and reading into my problems any replies would help. Thanks bentsprocket:helpacceleration gremlins
