whowutwut »
https://forums.nicoclub.com/whowutwut-u14197.html
Wed Jan 09, 2008 12:38 pm
I just swapped in an sr20 into my car last Aug and have been driving around very minimally, maybe 3000 miles at most. I have a ORC single stage clutch and it's must stronger than the oem clutch. I have removed the dampener. So after 4 months of driving, in Nov, the clutch pedal started to feel really soft, eventually I could not get it into gear. I went and looked at the clutch master cylinder and the fluid level is full, didn't go down. I looked at the slave cylinder and there's no sign of leaking fluid anywhere. But, when I went to bleed the clutch line, there seems to be a good amount of air in the line.. after bleeding, the clutch is fine...
So does this mean i have a slow leak in the salve cylinder? Or could it be caused by the heavier clutch disc? any way to be absolutely sure before replacing?
