slow acceleration
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
ozzyhype
Car: 2010 tiida
i hav a 2010 tiida and when i turn on my headlights i get a slow acceleration, i turned the headlamps of ( in the night :crazy: ) and the car started to accelerate rapidly turned them back on and back to the slow acceleration with my foot dwn. what could be he issue
ittim
Car: Micra 04
Hi, did you ever manage to fix this problem? i have the same problem on my K12 2004 Nissan Micra, I'd be interested to know how you fixed it.
Thanks
ittim
rstolz
Car: '13 Nissan Quest
'08 Nissan Versa
'84 VW Rabbit GTI w/1.8T drivetrain swap
likely an alternator or battery issue. both can get tested easily and cheaply, or you can do it yourself with a multimeter. either one may be in need of replacement, or it could be as simple as cleaning contacts.
everything is electronically controlled, and NIssans are very particular about maintaining proper voltage and amperage supply.
Return to “Versa Technical Discussions”
