1fst89240 »
https://forums.nicoclub.com/1fst89240-u30673.html
Fri Jul 15, 2005 8:11 am
well if it smells like brake, then a caliper might be seized, is the car a 5 speed or auto, check the transmission fluid (for the just reving problem) if its automatic but 5 speed it might be a bad clutch (not the siezed caliper), and if the car is leaking oil that badly I wouldn't suggest driving it around espically with no oil. There is probably something wrong with the pan gasket, did you remove it before?
