slow 240...help
Us13
Car: 90 s13 coupe
i just put a newer ka-e in my 90 s13 we got everything working and the car running good but it is horribly slow. this is the second one ive owned and thier is somthing wrong with this one. it like after partial throttle it doesnt matter, it feels like i am only throtling it a quarter to the floor. it has new dist. dist cap plugs and wires. some of the hoses might not be in the right spot if that helps. if thier is ant certain hose that would do that. it is just really sluggish and agervating. please help this is the last problem i am down to. oh also has new fuel pump...filter....and its not the injectors. any other ideas?
4gotn1
Car: 1990 Nissan 240sx (coupe)
i had a similar problem, check your ignition timing again. it might be off a little. if so then reset back to factory and see if that dosent help.
initial_d_s14
Car: 1995 240sx 1990 RX-7 1991 240sx
go buy a timing gun and check out the timing, my DE is doing that ever since i took the distributor off, i still havent fixed it
Us13
Car: 90 s13 coupe
my dist. was all the way on one side...so i moved it back towards the middle and it made a huge diffrence. but i dont know the factory settings for the dist. does any one know what they are? thanks for the help
