Put on the ones you got and get some wear on them. Then call later and tell them that they sent you the wrong ones but you didn't notice it until they were already installed. Maybe you'll get to keep both.DenverQ wrote:Well Ive been doing some reading on the powerstop site and they say that the cross drilled run 150 degrees cooler and the jist I got was that cross drilled were better. Awe man now do I suck it up or b**** and wait another week to get all my stuff. Man doin stuff yourself is hard because everyone else does their job half a**. Sorry for the vent
Don't forget the school of thought that advocates good old undrilled and unslotted rotors because they work just as well, and aren't as prone to cracking.palmerwmd wrote:Heavier is a good thing, because you have more of a heat sink.
As for functionality, there are two differnt schools of thought, one prefers slotted ,the other drilled.
I believe the slotted are at least (!) the equal of the drilled in fuctionality and they are also likely to be stronger than a drilled set.
Fred...![]()
We've had this same discussion before, but I have seen them crack on other cars, although they are a lot less prone to cracking than drilled rotors, and probably won't crack with street use. Introducing stress risers into brake rotors just isn't a good idea though IMO. If you want to upgrade your brakes, start with better pads, then go to bigger rotors/calipers if better pads alone aren't sufficient. Also, change the brake fluid out with a good fluid like Valvoline Synthetic at least annually.Q45tech wrote:Never seen any PowerStop drilled that cracked on a J/Q/G and we have installed over 200 sets in 5 years. Have seen some popular other brands of drilled rotors that have cracked [way too many vent holes and non directional].
