Sloppy Transmission Shifting !!
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
simon949
Car: 2007 Nissan Maxima "SL"
Do any of you 2010 EX35 owners have a problem with the way the 5-speed auto. transmission shifts when you give it some gas but not flooring it or just tell me how you feel about the shifting itself ?
jamesstock
Car: 2010 Liquid Platinum/Stone Journey
Diamond Cut IR Tint
Mine feels 'normal'. It shifts when it is supposed to shift, unlike some other MBZ when it just stays in 1st forever in the parking lot. I think the EX's 5 speed transmission is very mature.
txgcoupe
Car: 2007 G35 Coupe/ 2010 EX35
Mine is smooth as... Butter.
John
jmess
simon949 wrote:Do any of you 2010 EX35 owners have a problem with the way the 5-speed auto. transmission shifts when you give it some gas but not flooring it or just tell me how you feel about the shifting itself ?
Are you referring to the short shift to 2nd it does once you start rolling at low throttle angles? Putting the box in DS and/or selecting 1st gear will give you more control. The short shift is an attempt to save gas.
Other than this feature I find the box works pretty well. I try an anticipate when I will want more control and drop into DS and/or manually shift to a gear in advance.
simon949
That makes sense !
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
