Siizzzoooo »
https://forums.nicoclub.com/siizzzoooo-u6635.html
Mon Oct 17, 2005 6:15 pm
Ok, before i ramble, I'm going to list the parts I used, all NEW
Heavy Throttle SS clutch line, from Master cylinder to Slave lineSPL Parts SS Slave lineAdvance Autoparts Clutch master cylinderAdvance Autoparts slave cylinderExedy OEM replacement clutchnew tobnew pilot bearing97 5 spd ecu97 5 spd tranny97 5 spd driveshaftand other misc things you dont need to know
First off, the car starts up and runs fine, thats not the problem
We have bled the clutch, without any signs of air bubbles, as far as i can see anyway. The clutch pedal fails to become firm like it should be. Its really squishy and comes up really slow.
-The slave cylinder has good movement, and the fork moves fine. -The tob assembly was installed correctly with retaining clip.
The only thing I can think of is maybe the clutch pedal adjustment- there is quite a bit of free play, but i have the fork on the master cylinder all the way out just about. Even then theres a bit of free play. I didn't think backing it towards the firewall would do any good since it would pull the pedal closer to the floow.
OR maybe I just got some **** parts from Advance Autoparts...???
OR is bleeding stainless steel lines just hard?
Anyone have any tips or ideas?
thanks guys
