xtwoonamatchx »
https://forums.nicoclub.com/xtwoonamatchx-u73446.html
Tue Aug 04, 2009 4:29 pm
So, I drove my car the 3 hours to the beach, and about 2 hours into the drive, i realized my clutch wasn't working quite right. I shifted from 1st to 2nd, but my revs stayed at 4k even though i let the clutch out, then dropped down, and the same thing happened 2nd to 3rd. And now, if im sitting at a light, and just slowly let to clutch out to inch up, it feels as if the car is going to stall, but I used to be able to start moving, let the clutch out completely, without any gas, smoothly. It just seems weak.
I learned to drive a stick on my car, and was a bit wreckless at first. (17 year old, just got his license, maybe led to a bit of abuse =\ ) so there was definately a lot more clutch burnt than normal, but I have just over 26000 miles.
My questions are:a.) Do you think it just needs some adjustment or i burned it out?b.) if i burned it out, should i just have it replaced with an OEM clutch, or would it be cheaper/better to go aftermarket, if there is one?
Thanks for your time;I'll be able to get it to a shop next week, just want some preliminary advice.
