slip vdc and abs light on 2003 m45
kp1
Car: 2003 Infiniti M45
u gotta be kidding mei dont even have 50000 miles yet and im getting these problems does anyone know of a quick fix for this or have any advice..
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
kp1 wrote:u gotta be kidding mei dont even have 50000 miles yet and im getting these problems does anyone know of a quick fix for this or have any advice..
The problem may be due to power and/or grounding issues with the ABS-TCS Control Unit. So first make sure that the battery is good and that the alternator charging voltage is >13.8 VDC steady (spec is 14.1-14.7 VDC).
In most cases, the ABS-TCS lights illumination may be due to ABS Relay or one of the wheel sensors though other components like the ABS actuator, solenoids, G sensor, etc can fail so it is important to do a diagnostic check before replacing components. An ill-fitting tire chain can damage the harness to the wheel speed sensor.
Refer to BRC-16 for Component Location and BRc-38-40 for preliminary checks and inspections.
http://www.nicoclub.com/FSM/M/2003/brc.pdf
JOHNQ
Car: 99Qt
02 Q
03 M
kp1 wrote:
Sat Jul 24, 2010 4:53 am
Did you ever figure this out?
