texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Sat Jul 19, 2008 9:35 am
The TCS/Slip system on the Q45 is poorly integrated--in fact it is not integrated at all in my opinion. The ABS system is rock solid. If your ABS is working fine, it IS NOT a wheel speed sensor, since the same sensor output is used in both systems. It is either a faulty connection to the TCS/Slip computer, or something else in that system. First run the diagnostics with the TCS computer. Run it several times and see if any codes are consistent. Then unplug, clean, and use Stabilant 22 on all the pins and re-connect. Also remove, clean, treat as above and retighten all the ground wire connections ou can get to, especially the ones in the trunk and engine compartment. The system has to get 'clean' millivolt level signals from the speed sensors, the engine control module, ABS module, TCS module, Homeland Security Agency. A dirty /faulty connection of the battery cables, including the red 'plug-in' connections will cause wildly erratic system voltages and cause havoc. Even a failed noise suppressor condenser on a fan, or a bad fan motor (wiper motor, etc) will cause trash on the CAN and other wiring.
