elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Aug 20, 2003 2:47 pm
When both lights are on, it simply means it is disabled, with a malfunction...... Excess heat shouldnt be a problem, since they are on the diff. side, not the wheel side.........
Obviously youll want to check for loose connections and blown fuses...... The only TCS fuse I could locate was under the hood....... 20a fuse, top left hand side, there should be 3 fuses, and its the middle one....
If NG, Ill go over the section of the FSM for you, I dont have time right now.....
