Ewa_Bound07https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=7e18b889cf549a99b3307a4a367bda2dSLIP, RAS, LCDSat May 25, 2013 6:33 am
Postby
Ewa_Bound07 »
https://forums.nicoclub.com/ewa-bound07-u204375.htmlSat May 25, 2013 6:33 am
Has anyone had a problem with their SLIP, RAS and LCD light? After driving my 2007 M45 a few miles at a high speed I noticed the aforementioned warning lights came on. I turned the car off and on and the lights turned off so I thought everything was ok but as I continue to drive all three including the brake light came on.
I know I need new brakes so that is not my concern and I assume once they are replaced the brake warning light will go off...at least I hope so. My concern is about the SLIP, RAS and LCD. How important is it and does anyone recommend me taking the car in to be looked at?
Postby
Royal1262 »
https://forums.nicoclub.com/royal1262-u127901.htmlSat May 25, 2013 11:44 am
You may need to change your brakes. Pads possibly low. With those lights on it will not allow you to set your cruise control if you have intelligent cruise control feature because of safety reasons. Indicates low fluid and/or low brake pads.
