Slip light Question
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
Can I disconnect the computer in trunk,to make tcs lights go off?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You know there is a second throttle plate involved?
black g50
Yea,but wouldn't it just stay the way it is now..open? So if I pull the computer will they go out?
black g50
Maybe a fuse somewhere I could yank?
black g50
Maybe a wire I can snip?
black g50
No other cheap way besides taking dash apart,and pulling bulbs?
goody90q45
Car: 1992 Infiniti Q45 (sold)
Have you replaced the 2 relays under the battery?
94-q45-tcs-slip-light-t193188.html
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Talk with Qsiguy as he tried to get rid of those lights. Back in the day I would search for you and find you those posts of his....
http://c4caraudio.com/
aliciaford
Car: 1994 Infiniti Q45
Have you ever changed the relays under the battery? They cost me less than $40 and literally 10 minutes to replace. Lights went out on the first start up.
black g50
Yea living in the northeast,its either raining or snowing.Location of relay couldve been in a better spot,they dont like moisture much.Want to get out of this pattern of changing them out.When it works I usually turn it off,dont like the warning light on dash.
htbyrico
Car: 1996 Inifiniti Q45/ Nissan President
well i have traction control so my car started to make this sound then lights in the dash SLIP and TCS light on.. well that when on for a long time then my mushy brake petal, i was like :wtf2: :werd: .. anyway took off the traction control unit and the pump.. took every thing apart found my problem .. the spring in the pump broke and lock up the pump.. cleaned everything ordered new seals and took the spring out never replace them.. put the pump on a vice and test and work like new.. cleaned traction control unit new seal and o ring put everything back.. found lot of rust build up in it.. so i said how can this be it all sealed?? well the pump seal i replaced was letting water seep in as it rain and i went over water.. my wheel cover had broken and i never did fix it on the passenger side.. wow what a job it took a few day waiting on parts.. so now i started to put everything back in and tighten all lines and finish the job flushed out all old brake fluid and changed my brake pad front and rear.. got a friend to help me bleed the system.. and when i got to the rear no pressure at all .. now im lost !! took a damm brake now i was so F-ing mad.. then i seen the bleed screw on the master cylinder.. unhaa.. had my friend pump and pump and i open the bleed screw.. nothing but air!! i was so happy then.. after that i went back to the rear calipers open them up and they were shooting out like water guns!! wow all this work and there it was miss that screw on the master cylinder.. turn the car on and went on a fast ride !! my slip light and tcs light was solved.. AND BRAKE STOP ON A DIME !! let me know if this helps you.. im a technician at cottman transmission.. when i fix something it get fix,, feel me!! :bigthumb: :dblthumb:
