slip and tcs off lights staying on in my active...why?
pretzelboy
The other day the slip and tcs off lights went on....I shut off the car and restarted and they were fine...now every time I start and put it in gear they light and stay on....should I be concerned?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Could be the relays are going bad...... under the battery
qship96
Car: 1996 Infiniti Q45
oh yeah,especially this time of year,with snow,as when lit up,the entire traction control system is inoperative.common for the relays to stick or fail-located near bottom of battery-order both from joe, about 20-25 bucks.hopefully,this will fix it,if not there are 2 modules that must be tested to diagnose problem-one is in trunk,the other i believe is under dash by steering wheel.
pretzelboy
relays like a $5 part or $500 part?
pretzelboy
what does the slip light mean?
elwesso
2007 BMW M Coupe
Slip light comes on that lets you know that the the TCS id doing something.. it will come on when you lose traction...
Relays are under the battery and probably $30 from Joe..... Like Qship said
The control unit is in the trunk... Replace the relays and then report back.....
qship96
in normal,correctly operating system,all indicators are dark during driving,if system detects a wheel is slipping{rain,ice,snow,etc} the slip indicator illuminates,indicating the trac system is engaged,pulsing the brake on slipping wheel and or cutting air flow by means of a secondary throttle plate to reduce engine output to stop the spinning wheel.
pretzelboy
these relays under the battery will be obvious?
elwesso
2007 BMW M Coupe
yes..... Very obvious as they are the only 2 relays under there (no relays for non TCS cars)
