Slightly shorter tires on 99 Q45T - possible ill effects...
greenwar
Car: 08 WRX
Winter is approaching and I am looking to get ready for the heavy snow falls of minnesota. My 99 Q45T has stock tires sized 225/50 17 load index is 95 and Speed rating is V.
I have a like new set of 15" 215/60 15 wheels with snow tires load index 94 - speed rating T. I checked the size, it seems the 15" tires will be around 3% shorter than the OEM 17" tires.. Do you guys think I will be taking a big risk driving around in shorter tires.. What are the possible mechanical draw backs of using such short tires..
Please enlighten me.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
They won't fit. Why Infiniti went to a 16" wheel on the FY33, because of larger front rotor diameter.
They'll wear much faster at high speeds, which sounds dangerous -- I drive at high speeds often. Speedo will be a bit off.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Jesda wrote:They'll wear much faster at high speeds, which sounds dangerous -- I drive at high speeds often. Speedo will be a bit off.
Agreed, high speeds and Minnesota snow are a bad combination.
Your speedo will be off and as long as all the tires are the same size then not much else (REALISTICALLY).
P.S. I have a set of 16 20 hole turbines (stock on my 97) that would be perfect for snow tires. I'll sell you them for cheap and they'll fit!![email protected]
Andy:
I -may- be interested in those. Please send a price to [email protected]
greenwar
Car: 08 WRX
Dang. Quote me a price on those turbines as well. Let me see what my pocket says..
Thanks for the inputs guys. Appreciate it as always.
