Slightly Damaged SR20DET Crank and Alternator Pulleys - Replace?
voiddweller
Car: 97 Nissan 240SX SE w/S13 SR20DET
04 Honda Accord CL9
I'll post picks tomorrow, but there is about a 1/2" chunk taken out of the lip of the crank pulley. Another 1/2" section of the outer lip on the alternator pulley is bent 1/8" toward one of the ribs.
Since the crank is blanced, should it be replaced or is 1/2" on the lip diameter not that much to worry about?
Thanks.
180fan
Car: 89 fastback
Yikes! yeah change out the busted pulleys.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Balance isnt as much an issue as your belts slipping off and ****ing your day up good.
voiddweller
04 Honda Accord CL9
Thank you for the feedback.
If they need to be replaced, is there an equivalent (ie. KA or FWD SR) that I can pick up in the U.S.? If not, do I have to source pulleys from an older RWD S13 SR20DET or some other Nissan motor?
Thanks.
Here are pics:
