Slight Wiring Problem
mattlord42
Car: 1991 240SX Coupe
Hey guys we got our little project CA all nicely installed and all of the engine bay plugs plugged in nicely and all that stuff. Our problem is the plug on the EFI harness just up from the ECU - this plug is labelled as EFI harness plug F1 in the FSM - it should plug into Main Harness Plug M53. Our problem is that both plug F1 and plug M53 are male plugs. Anyone have any advice? I will try to get some pictures up asap.
Thanks,Matt
skoob240
I used a female plug from another 240sx KA harness.
NeedCAforS13
Car: CA swapped S13 coupe
same here
Sean
mattlord42
Cool-
Did you guys have to repin the connector or did you just cut and splice wires by matching colors?
Matt
