Slight vibration coming from passenger rear
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
well. I was putting the Q up for winter and unfortunately i hit the rear with the trailer. Was sliding a bit much since we just got a fresh foot of snow. THICK wet stuff The hit wasn't too bad. Rear tire/rim was hit by while trying to load one of my winter beaters up. ya ya yell at me all u want, i had a buzz and been working alot lately so i was trying to do it quick. Fortunately no body damage but it moved the car about 6 inches. Took it for a ride and got some nasty vibration from the pass rear. Got an alignment but still vibrates slightly throughout the car from 40 MPH on. Damage do the control arm im guessing or possibley bent rim? any input would be nice.
silkysmoothyjud
Car: 1994 Q45
crap stuck in the tire? if it was something serious it would be doing it at all speeds. I just had a tire "fixed" and have a massive vibration now, but mine dont occur until after 60mph or while making a left turn. I am about to move said tire to the back and do a couple of 360s to smooth it out again. Rotate your tires to narrow it down...You will always get a slight vibration after an alignment, I always do for about 300 miles or so. Then, yes you guessed it, silky smooth baby!
BCC93QT
1995 Infiniti Q45
well the tires are pretty new. Have to rotate tires with my oil change this weekend. Never has vibrated this bad in the past. Just after the contact. It can't be stuff in the tires it only sat for like 5 days and it was smooth when i parked it. I don't have a day off until after xmas so i will check it out then. I have alot of things i have to do before i put it back on the road in the spring.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Don't way what kind of tires, butgood ones strong enough for a G50 often have nylon cords in them, and they don't take well to a cold set.
BCC93QT
1995 Infiniti Q45
running Yokohama Advan sports.... with my experience a great tire for the Q so far. Im not stressing it. After the holidays im back to 3 days off a week. Plus off for a month for school. gonna get alot done this winter. Nothing to do up here in MA when its snowy.
silkysmoothyjud
Car: 1994 Q45
It could have put flat spots in em all....6 inch slide....could have stressed a wall in the tire too. That tire repair I was talking about; they put a black nub in it. Said nub is sticking out of the tread causing a nasty vibration over 60. I am gonna cut it down with a razor, move it to the back and light it up!!!
All that snow and sliding could have wedged something in the treads. We hope....good luck!
silkysmoothyjud
Car: 1994 Q45
I did it, and now the vibration occurs over 85 with the tire lit up on the back. Oh well, at least I have a speed warning system now!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
N/A
Last edited by Infinitiguy19 on Sat Jan 08, 2011 10:32 pm, edited 1 time in total.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Good gosh Paul. You're NICO's living, breathing search function (you and Lino).
Have you considered Library Science for a major?
