climo »
https://forums.nicoclub.com/climo-u10164.html
Mon Nov 17, 2003 6:16 am
I recently purchased my S14 and all though she drives great there is something going on with the front end/engine.
I have a slight vibration from the steering wheel that is starting to make my hands go numb after a few hours driving. I think the vibe is coming from the engine and is transmitted to the steering rack. Sometimes you can see the wheel vibrating and other times its rock solid.If I cruise down the road at about 40 then apply gas, I can feel the car resonate with a vibration, and if I let off the gas the vibe almost goes away. So I guessing its rpm dependant. If I rev it up w/o moving I really don't notice it as much. Only when moving.
Its a 98 240 w/auto. all stock with 186k. I've replaced the tires and had them balanced but that didn't help. I will be replacing the wheel bearings, struts, springs, ball joints, and whever else I can replace on the front. Just so I know its all new parts. The engine vibration is another thing.
Can anyone give some suggestions on what may be causing the engine to make the whole car resonate? Since it does have some high miles what else should I replace? Center-bearing support maybe?
