if the carrier bearing is bad would it still let it bounce around even in park?180fan wrote:thumping in the tunnel for the transmission? it could be your transmission shifting around with a blown transmission mount or the carrier bearing for the driveshaft has kicked the bucket.
I'll ask you again, does it change?rogoman wrote:When you rev up the motor, does the frequency of the noise change?
